Scilab Function
Last update : 3/10/2006
cgal_stream_2 - Computes the streamlines of a given regular vector field.
Calling Sequence
cell = cgal_stream_2(u,v,sd,[step])
Parameters
Description
Creates a placement of streamlines according to a specified density and gives access to those streamlines via a cell array.
Examples
load('data/field','u','v')
c = cgal_stream_2(u,v,1.5);
cgal_streamlines(c);
See Also
cgal_streamlines ,
for more details see CGAL Manual.
This function uses the Streamlines package of CGAL, which is under QPL license. See License Terms
Authors
Naceur MESKINI.
