Scilab Function
Last update : November 2005
cgal_mesh2_set_seeds - Set seed points of a domaine
Calling Sequence
cgal_mesh2_set_seeds(ptr,x,y)
Parameters
Description
The seed points defines components,of a domain,that will not be meshed (holes).
Examples
C=[1 1 5 1; 5 1 7 3; 7 3 4 4; 4 4 3 6; 3 6 1 5; 1 5 1 1;...
5 2 5 3; 5 3 3 4; 3 4 2 2; 2 2 5 2];
[coord,tri,ptr]= cgal_mesh_2(C);
cgal_mesh2_set_seeds(ptr,3.5,2.5);
tri = cgal_mesh2_get_connectivity(ptr);
coord = cgal_mesh2_get_coord(ptr);
clf();
[nbtri,nb] = size(tri);
tri = [tri tri(:,1)];
x=coord(:,1)';
y=coord(:,2)';
for k = 1:nbtri
plot2d(x(tri(k,:)),y(tri(k,:)),style = 2);
end
cgal_mesh2_delete(ptr,"ptr");
See Also
cgal_mesh_2 ,   cgal_mesh2_refine ,   cgal_mesh2_get_connectivity ,   cgal_mesh2_get_coord ,   cgal_mesh2_delete ,
This function uses the Mesh_2 package of CGAL, which is under QPL license. See License Terms
Authors
N.Meskini
