Scilab Function
Last update : November 2005
cgal_delaunay_3 - Delaunay triangulation of a set of points in 3d space.
Calling Sequence
[tri [,ptr] ] = cgal_delaunay_3(x,y,z);
Parameters
Description
A Delaunay triangulation of a set of points is a triangulation of the sets of points that fulfills the following empty circle property (also called Delaunay property): the circumscribing circle of any facet of the triangulation contains no point of the set in its interior. For a point set with no case of cocircularity of more than three points, the Delaunay triangulation is unique, it is the dual of the Voronoi diagram of the points.
Examples
x =rand(1,10);
y =rand(1,10);
z =rand(1,10);
tri = cgal_delaunay_3(x,y,z)
!   10.    2.     3.     4.  !
!   2.     1.     3.     4.  !
!   5.     1.     2.     9.  !
!   9.     2.     3.     10. !
!   3.     1.     2.     5.  !
!   1.     2.     7.     4.  !
!   1.     5.     3.     4.  !
!   9.     2.     10.    7.  !
!   7.     2.     10.    4.  !
!   8.     1.     2.     7.  !
!   9.     8.     2.     7.  !
!   9.     1.     2.     8.  !
!   6.     7.     10.    4.  !
!   6.     10.    3.     4.  !
!   1.     7.     8.     4.  !
!   9.     7.     6.     8.  !
!   5.     9.     6.     8.  !
!   5.     1.     9.     8.  !
!   3.     5.     9.     6.  !
!   3.     5.     2.     9.  !
!   6.     9.     10.    7.  !
!   6.     9.     3.     10. !
// use the pointer if you want to interact with dt3.
[tri,ptr] = cgal_delaunay_3(x,y,z);
cgal_dt3_insert_points(ptr,rand(1,100),rand(1,100),rand(1,100));
new_tri = cgal_dt3_get_connectivity(ptr);
cgal_dt3_delete(ptr,"ptr");
size(new_tri)
 ans  =
!   579.    4. !
See Also
cgal_delaunay_2 ,   cgal_delaunay_n ,   cgal_constrained_delaunay_2 ,
For more details see CGAL Manual.
This function uses the Triangulation_3 package of CGAL, which is under QPL license. See License Terms
Authors
Naceur MESKINI
