Scilab Function
Last update : November 2005
cgal_delaunay_2 - Delaunay triangulation of a set of points in 2d space.
Calling Sequence
[tri [,ptr] ] = cgal_delaunay_2(x,y)
Parameters
Description
A Delaunay triangulation of a set of points is a triangulation of the sets of points that fulfills the following empty circle property (also called Delaunay property): the circumscribing circle of any facet of the triangulation contains no point of the set in its interior. For a point set with no case of cocircularity of more than three points, the Delaunay triangulation is unique, it is the dual of the Voronoi diagram of the points.
Examples
x =rand(1,100);
y =rand(1,100);
tri = cgal_delaunay_2(x,y);
[nbtri,nb] = size(tri);
tri = [tri tri(:,1)];
for k = 1:nbtri
plot2d(x(tri(k,:)),y(tri(k,:)),style = 2);
end
See Also
cgal_delaunay_3 ,   cgal_delaunay_n ,   cgal_constrained_delaunay_2 ,
for more details see CGAL Manual.
This function uses the Triangulation_2 package of CGAL, which is under QPL license. See License Terms
Authors
Naceur MESKINI.
