Scilab Function
Last update : November 2005
cgal_cdt2_get_connectivity - Get the connectivity of cdt2,constrained Delaunay triangulation.
Calling Sequence
tri = cgal_cdt2_get_connectivity(ptr);
Parameters
Examples
x = [5 1 6];
y = [2 6 6];
C=[8.    2.     7.    4.;6.    4.5    4.    5.;3.    6.     3.    7.;3.    4.     2.    3.;9.    4.     8.    7.];
[tri,ptr] = cgal_constraind_delaunay_2([],[],C);
cgal_cdt2_insert_points(ptr,x,y);
coord = cgal_cdt2_get_coord(ptr);
clf();
X=coord(:,1)';
Y=coord(:,2)';
[nbtri,nb] = size(tri);
tri = [tri tri(:,1)];
for k = 1:nbtri
plot2d(X(tri(k,:)),Y(tri(k,:)),style = 2);
end
cgal_cdt2_delete(ptr,"ptr");
See Also
cgal_cdt2_insert_constraints ,   cgal_cdt2_insert_points ,   cgal_cdt2_remove_constraints ,   cgal_cdt2_remove_points ,   cgal_cdt2_insert_points ,   cgal_cdt2_get_coord ,   cgal_cdt2_delete ,
This function uses the Triangulation_2 package of CGAL, which is under QPL license. See License Terms
Authors
Naceur MESKINI.
